Date/Time: Sun, 12 May 2024 20:04:30 +0000
[Programming Help] - Ask/Bid Volume difference bars
View Count: 970
[2019-07-29 15:47:40] |
User968625 - Posts: 256 |
Hello, Is there a way to NOT invert the -ve delta bars. I like to use it as background filled bars under volume for easy interpretation as well as space. Here is an image using another delta custom indicator but it is not exact delta so not as accurate as the Ask/Bid Volume difference bars Thank you |
Volume with Delta Background.png / V - Attached On 2019-07-29 15:46:56 UTC - Size: 1.05 KB - 411 views |
[2019-07-29 19:48:55] |
Sawtooth - Posts: 3995 |
Use two instances of the Spreadsheet Formula study, one for each color: -Hide the Ask/Bid Volume Difference Bars study. -Green formula: =IF(ID17.SG4>ID17.SG1,ID17.SG2,0) -Red formula: =IF(ID17.SG4<ID17.SG1,-ID17.SG3,0) where ID17 is the Ask/Bid Volume Difference Bars study; edit formula as needed. Note: the Volume study must be below both Spreadsheet Formula studies in the Studies to Graph list, and set all studies to the same Chart Region. |
[2019-07-30 00:18:03] |
Brilliant. works perfectly. thank you so much @tomgilb for sharing your knowledge and your time
