Date/Time: Thu, 09 May 2024 09:55:13 +0000
Charting Options Contracts
View Count: 668
[2019-07-29 14:51:19] |
User350051 - Posts: 16 |
Is there a way to chart options contracts? What data package do I need to do? Thx
[2019-07-29 18:56:36] |
We need to know what particular type of options you are referring to?
[2019-07-29 19:05:52] |
Sorry I should have put in. Equity options so say like AAPL Monthly Call
[2019-07-30 18:09:30] |
For equity options you need to use IQ Feed: DTN IQ Feed Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
