Date/Time: Fri, 10 May 2024 12:27:42 +0000
Chartbook tabs
View Count: 518
[2019-07-29 05:49:52] |
User27542 - Posts: 20 |
I would like to make all my chartbook tabs visible (in the row at the top just above the charts display) instead of having to scroll through them to find the one I wish to display (if there are more than about 30 chartbooks). This would require more than the single row of tabs currently shown. Is there any way I can do this? With thanks for any help you can give.
[2019-07-29 05:56:11] |
There is not currently the capability for multiple rows of tabs but we will work on adding that. For now you can quickly find all of your open Chartbooks through the CB menu at the top of the main program. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
