Date/Time: Mon, 29 Apr 2024 00:45:09 +0000
Show account number on chart
View Count: 1815
[2019-07-28 19:02:42] |
User79074 - Posts: 105 |
Is there a way to show the account number of a live trading account on the chart? For example, when in sim mode on the chart it shows in the upper left hand portion of the chart for example "[Sim1] Trade: 100@1032.33". During live mode can it be set to show my real live account for example "[123456] Trade: 100@1032.33"
[2019-07-28 23:11:47] |
This is not supported. Although there could be a study created to do this relatively easily. But you can see the Trade Account number on the Trade Window: Basic Trading and the Trade Window: Trade Window Controls Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-29 08:58:58] |
Thanks for the response but, I don't see why this is supported when in Sim mode, but when in live mode we cannot see the same information. Should be a simple feature to add in the code "Display Account number in Chart Trade Mode Box".
Date Time Of Last Edit: 2019-07-29 08:59:33
[2019-07-29 17:14:15] |
That is because in Trade Simulation Mode the account identifier is a short known length. It is not something unpredictably long. But we can add an option to control the display of it for non-simulated trading.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-29 17:28:14
[2019-07-29 17:33:15] |
I would greatly appreciate it! Thank you!
[2019-07-30 12:26:01] |
Will this be released in the next update?
[2019-08-05 10:43:37] |
No pressure, but just would like to know the time frame from the SC team. Thank you
[2019-08-06 01:57:33] |
We expect this to be done sometime in the next two weeks.
[2019-08-15 08:24:39] |
Is this in the 1973 release?
[2019-08-15 08:33:26] |
No, we have not yet gotten to it. There is another significant task we need to finish with first.
