Date/Time: Tue, 14 May 2024 04:50:17 +0000
Backtesting feature?
View Count: 624
[2019-07-28 14:47:00] |
User316362 - Posts: 210 |
I don't think this option exists, however it would be very nice for those of us that use backtesting a lot. Would it be possible to set up a replay "Without" having the chart walkthrough ever bar (at whatever speed)? Basically, turn off the display of the walkthrough temporarily. But instead, just perform the replay on the data (in the background) and show the completed results in the trade statistics? Also, in addition, then possibly refresh the chart when completed to see the trades? Seems the walking through of the display/graphics is very time-consuming. Especially when one wants to backtest a year for instance. Not sure why its so slow since all resources being used are extremely low (CPU, GPU, Disk, Memory, Network, etc), including graphics cards. I could even imagine a % progress being displayed in the replay window based upon start bar number and chart last bar number. Date Time Of Last Edit: 2019-07-28 15:43:03
[2019-07-29 18:55:13] |
You can hide the chart during the back test but it is not going to make any difference performance wise, or at least very little. Refer to: Window and CW Menus: Hide Window (Window) To improve performance, refer to: Auto Trade System Back Testing: Improving Back Test Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-29 18:55:25
