Date/Time: Fri, 03 May 2024 22:38:18 +0000
Wide Range Bar defined by prior range
View Count: 1045
[2019-07-24 16:40:58] |
User92573 - Posts: 483 |
Dear Forum/Support I'm trying colour (or dot above) a wide range bar that is defined by the average range of n prior bars x a multiplier. If Bars Range > (Multiplier * (Sum(High - Low) of n bars)/n bars). SC has a WRB study but its not quite what I wanted. Any help appreciated. Thank you. Date Time Of Last Edit: 2019-07-24 21:33:14
[2019-07-24 21:30:26] |
I see it was requested back in 2018. Wide Range Bar with some condition | Post: 137071 Any thoughts? Thanks PH |
[2019-07-26 04:51:48] |
We will look this over.
[2019-07-28 01:48:03] |
SC Support Tom - Posts: 450 |
Hi, this will be easy to do. I will add this option as Scheme #3 to both the Wide Range Bar and Narrow Range Bar studies.
[2019-08-03 13:25:54] |
Many thanks!
[2023-03-07 05:26:01] |
User624595 - Posts: 183 |
Could you add the option on this study to calculate/alert only after a bar is closed?
