Date/Time: Tue, 17 Nov 2026 17:18:33 +0000
pb concerning connexion
View Count: 935
| [2019-07-24 13:37:20] |
| User758506 - Posts: 9 |
hello Ive trouble with the connexion I don't understand why thanks for your help |
| [2019-07-24 17:58:19] |
This issue is explained at the beginning of this section here: CQG Trading Platform Service: Frequent Server Disconnections when Using CQG You have more than one connection to CQG at the same time. Do you need to be connected more than once at the same time? This service here supports that: Sierra Chart Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
