Date/Time: Sun, 12 May 2024 22:18:10 +0000
UDP command to close chart
View Count: 672
[2019-07-24 13:01:25] |
User79074 - Posts: 105 |
Can you make a UDP command to close a chart. There is a UDP command to open a chart, but I would like to be able to close it as well. Thank you
[2019-07-26 05:35:18] |
No but this is supported by ACSIL: sc.CloseChart() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-27 12:15:09] |
What about being able to load certain study with a chart? This would prove useful for automation for example to be able to load symbols dynamically and add any study to them. Would you be able to add this as a UDP command? I am not interested in the "Use default Study collection for New Charts" since that fixates only one study collection. I would like to be able to apply different study collections and individual studies from the command line.
Date Time Of Last Edit: 2019-07-27 12:17:25
[2019-07-28 05:10:14] |
What we can do reasonably for now is add an ACSIL function to apply any previously saved Study Collection to a chart.
[2019-07-28 12:14:51] |
Ok, that would be helpful. For some reason when I save a study collection I don't see the corresponding .stdycollct file in the Data folder.
Date Time Of Last Edit: 2019-07-28 12:15:12
[2019-07-28 21:18:17] |
This would mean there has been an error saving it. Check the Window >> Message Log for the error.
