Date/Time: Wed, 01 May 2024 12:19:40 +0000
DOM
View Count: 1033
[2013-12-04 17:06:41] |
User39772 - Posts: 311 |
When the price moves to the lower/upper end of the window it does not center and runs out of the window. There is also no way (eg scroll bar) to center it manually. |
[2013-12-04 18:34:58] |
What you need to do is double-click on the price scale. And it will automatically center. You can also right-click on the price scale and select Scale Range: Constant Range AutoCenter. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-04 18:35:48
