Date/Time: Tue, 17 Nov 2026 17:18:30 +0000
Overlaying an input or subgraph value from one study onto a destination chart
View Count: 2264
| [2019-07-20 21:28:54] |
| User626032 - Posts: 36 |
My objective: On a 10 range Renko to show (with a small horizontal line) the VPOC for each bar. What I've done: Produced a 10 range Renko footprint chart and overlayed only SG2 (POC) onto my regular 10 range Renko chart. It will only give me the POC as extend until intersected, which is a graphical mess. Is there a formula that I can use with the Color Bar on Alert Study or any other study to extract this value and plot it on each bar. I thought about a volume profile chart but they seem to be time based only. In a similar vein, I am also trying plot the only the daily POC from a daily TPO chart onto other bar charts (with this I am not concerned about the value extending until intersection). I've searched throughout the Sierra Chart database trying to figure this one out. Dead end so far. |
| [2019-07-22 19:40:46] |
| John - SC Support - Posts: 48550 |
With regards to the first item about the VPOC, we are not exactly sure what you want in terms of extension lines, etc., but it sounds like what you want can be accomplished using the Volume by Price study directly on the Renko chart. You can use the VbP with a non-time based chart by using the number of bars setting. We have put together the attached Study Collection that has a VbP study on it with the settings as we think you want them. Note that we have set the Draw Style for the POC to Dash to give you the lines as they are. Refer to the VbP study information here: Volume By Price Study With regards to the second question about copying the POC from a TPO, you would need to have another chart that uses the TPO Value Area Lines study, then use the Study/Price Overlay on the TPO Value Area Lines to copy the POC to the other chart. Refer to the documentation for the TPO Value Area Lines study here: TPO Value Area Lines And refer to the documentation here for the Study/Price Overlay: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-22 19:41:03
| [2019-07-23 21:29:23] |
Thanks. Works perfectly! Cheers |
