Date/Time: Fri, 17 May 2024 17:37:30 +0000
Multi Threading *.scid file loading
View Count: 882
[2019-07-20 14:23:09] |
User541156 - Posts: 67 |
Is it possible to use multiple threads when changing timeframes? Loading from *.scid files seems to only use a single thread and can be very slow despite having high-end CPU with one of the highest single-thread performance. |
[2019-07-20 21:12:29] |
No this is totally impossible. You cannot create a single series of bar data on multiple threads. Make sure you have Sierra Chart running on a dedicated SSD and using a NVME drive.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-20 21:15:04
[2019-07-21 01:40:08] |
That's alright. Yes, I do have nvme, and enough RAM and 8700K. The only limit which is touched is single-thread performance. Date Time Of Last Edit: 2019-07-21 01:44:10
Annotation 2019-07-21 110801.png / V - Attached On 2019-07-21 01:39:36 UTC - Size: 196.5 KB - 337 views |
