Date/Time: Sun, 12 May 2024 10:33:59 +0000
high cpu while replaying and then losing sync
View Count: 648
[2019-07-20 04:36:36] |
onnb - Posts: 661 |
I am running a long replay. I have speed at x30 and replaying two chart using "charts with same link" option. I am using the "Calculate at Every Tick" option For first few hours it runs fine. After few hours, it slows down significantly and cpu is quite high. Often I pause the replay, let the cpu go down and then press play again, continuing from the same point where I paused - it stars off again at the expected speed and everything fine. Sometimes after pause when I restart, it start running but charts are out out of sync. What is strange to me is that the cpu only goes high like after several hours. Is this behavior known ? |
[2019-07-23 03:49:19] |
To avoid losing synchronization, refer to this section: Replaying Charts: Automatic Skipping of Periods Where There Is No Trading and Synchronization You need to rule out your custom studies for the source of the issue by removing them from the chart. What is strange to me is that the cpu only goes high like after several hours. No we do not know why.
Is this behavior known ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-27 08:04:30] |
We are working on a performance optimization regarding timers in Sierra Chart. This will be fully released tomorrow. Contemplating this again we think it might relate to an accumulation of timer messages in the queue. This kind of problem is going to be definitively solved in version 1960. Sierra Chart already clears out excess timer messages but it may not be at a rate which is fast enough in your particular scenario. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
