Date/Time: Fri, 17 May 2024 18:44:24 +0000
Incomplete Extended Rectangle
View Count: 810
[2019-07-19 15:57:47] |
HinckleyBob - Posts: 45 |
When I manually draw an extended rectangle from 55.57 to 54.97, the fill extends only to ~55.27. The selection and properties dialog confirm where the top and bottom are supposed to be. The fill is specified as illustrated by the Options tab of the properties dialog. The chart is linked to a single other chart, and that linked chart shows the same flaw. Behavior is consistent and reproducible. Thank you, Bob |
2019-07-19_11-44-30.pdf - Attached On 2019-07-19 15:53:05 UTC - Size: 35.63 KB - 257 views |
[2019-07-19 16:39:49] |
If you are using the OpenGL option, then be sure to state that. That option is still a beta and does have known issues. We do see another post from you about a problem and we will get to it as soon as we can. There is no need to post about any further OpenGL graphics issues because they are known. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-19 16:40:10
