Date/Time: Sun, 19 May 2024 03:16:46 +0000
Only POC on Candle
View Count: 621
[2019-07-19 14:16:42] |
User33743 - Posts: 83 |
Hello I was trying to get ONLY POC Visible per one candle from "Number Bar" study but seems that something doesn't work. Is this possible to make it work? TY |
[2019-07-19 16:29:38] |
There is not support for this but we will look at adding an option for this.
