Date/Time: Tue, 21 May 2024 13:08:32 +0000
Trade Configuration name in TradeactivityLog Notes
View Count: 525
[2019-07-19 11:39:57] |
Thedaytrader - Posts: 1 |
Dear support, I have a problem with the assignation of Trade Configuration name in TradeactivityLog Notes. The open positions trades are correctly assigned but the oco orders relatives to the trade are not display correctly in the Notes (leaving just a blank field). This create a problem in order to calculate pnl of a specific strategy. This generate problems when filtering by notes in "Period Stats". Is it possible in order to simplify the process modify the "note" field in the .txt files and import it? Thanks in advance Date Time Of Last Edit: 2019-07-19 12:31:29
problem.JPG / V - Attached On 2019-07-19 11:38:45 UTC - Size: 21.72 KB - 192 views |
[2019-07-19 17:08:57] |
We see what the issue is. This will be solved in the next release. The text tag is not copied to the Attached Orders.
