Date/Time: Tue, 21 May 2024 19:29:50 +0000
Is it possible to have an attached order that uses a fixed price stop
View Count: 467
[2019-07-18 17:51:46] |
jseppa - Posts: 18 |
To enter trades, I'm using "Stop with Bid/Ask Triggering". I'd like to be able to set my attached stop with a set offset to the parent order, but I do not want it to update based on the fill. Eg, Say I set a buy stop to 1.50, and my attached stop is 5 ticks, 1.45. Say I get filled at 1.53, I want my stop to remain at 1.45, not be adjusted to 1.48. Is this possible? |
[2019-07-18 18:26:39] |
Yes. Refer to this setting: Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General) You will need to disable that option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
