Date/Time: Wed, 22 May 2024 01:09:20 +0000
1952 OpenGL enabled bug
View Count: 645
[2019-07-18 16:28:44] |
User786248 - Posts: 25 |
Hi When I enabled open GL my hollow candlesticks are no longer hollow. Maybe a bug to be fixed. Hollow version 1952 with open GL enabled http://www.sierrachart.com/image.php?Image=1563450330434.png Hollow candlesticks version 1952 with no Open GL enabled http://www.sierrachart.com/image.php?Image=1563450451259.png using GTX 1070 Thanks you |
[2019-07-21 21:29:56] |
Provide that chart by following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
