Date/Time: Tue, 21 May 2024 16:44:36 +0000
Using different data feed on new instance
View Count: 560
[2019-07-18 16:26:47] |
User383849 - Posts: 23 |
Hi! I can't seem to select a different data feed on new instance. |
[2019-07-18 18:06:46] |
If you are talking about a Sub-Instance (started by selecting File >> New Instance), then that is how that feature works. The Sub-Instance is connected to the primary instance and gets the data from the primary only. If you want to be able to connect to two different data feeds/brokerages at the same time from Sierra Chart, then you will need to install a completely separate installation of Sierra Chart (this can be on the same computer, just in a different directory). Refer to the following documentation on this: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
