Date/Time: Fri, 17 May 2024 18:41:53 +0000
how to you hide or display the header with all of your open workspaces
View Count: 1095
[2019-07-18 14:23:42] |
User665173 - Posts: 8 |
how do you hide or display the header that shows all of your open workspaces
[2019-07-18 18:11:53] |
What you are referring to is the CB menu on the main program window. You cannot remove that.
