Date/Time: Sun, 28 Apr 2024 17:01:22 +0000
Connecting line do not displaut on other chart
View Count: 1456
[2013-12-03 20:15:54] |
User53601 - Posts: 105 |
I have two charts with the same symbol linked together via Charts settings/Advanced Setting 2/Link number. One chart displays the connecting lines, but the other chart not, and I need to display it. I have the following settings: Chart Trade Setting/Display Entry/Exit Connecting Lines is checked Chart Trade Mode On is checked. I have another pair of charts with different symbol, and there is no problem, connecting lines are displayed on both charts. Can you please advice? thank you |
[2013-12-05 03:20:22] |
You need to also enable Trade >> Show Order Fills for the chart.
[2013-12-05 07:33:04] |
That is it. Thank you |
