Date/Time: Mon, 20 May 2024 22:36:55 +0000
What ever is 1st on Studies to Graph does not adjust with the rest.
View Count: 563
[2019-07-17 17:56:45] |
User731023 - Posts: 128 |
Hi, I am on version 1940. Whenever you adjust the chart whatever is at the 1st Studies to Graph does not adjust with the rest. Please see snapshots. |
[2019-07-17 22:31:41] |
John - SC Support - Posts: 31758 |
This is just a Scaling issue. There are a couple of possibilities for what you are seeing. The most likely, given your statement about the first study, is that you have the Left Side Scales turned on. When this is on, the first appropriate study will use the left side scale instead of the one on the right with the rest. Refer to the following for this: Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) The other possibility is simply that those studies are not using a Scaling setting of Automatic. Check each study and ensure that they are all set to Automatic (or if not, then be aware that they will not scale with the other items in the chart). Refer to the following for how to set the scale for a study: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-19 21:38:38] |
We are looking into this because you cannot use an Automatic scale in the case you presented and if you are not using the Left Side Scale maybe the other graphs in Chart Region 1 should automatically adjust with an Interactive Scale Range/Move.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-19 21:39:04
