Date/Time: Wed, 29 May 2024 06:20:34 +0000
How to split TPO chart
View Count: 1832
[2019-07-17 03:47:36] |
User500835 - Posts: 2 |
I've spent hours trying to figure this out, and went through all the help material I could find, and am totally stumped. I attached a screenshot of how I have the times entered. I want to have 2 separate profiles. One for regular trading hours and one for afterhours. I want the regular trading TPO to start at 07:30 and end at 14:29:59 I want the afterhours TPO to start at 14:30:00 and end at 07:29:59 No matter what I do, I can't get two separate profiles to display. Please provide instructions showing me what times go in what slot, and which check boxes to use in order to achieve this. I'm sure I've tried every combination twice, and cant figure this out |
Screenshot (15).png / V - Attached On 2019-07-17 03:37:44 UTC - Size: 144.22 KB - 388 views |
[2019-07-17 07:55:06] |
How to do this is documented here: Time Price Opportunity (TPO) Profile Charts: Displaying Separate Profiles for Day and Evening Sessions In the Chart Settings you need to set the Session Times as follows: Start Time: 07:30: 00 End Time: 14:29:59 Evening Start Time: 14:30:00 Evening End Time: 07:29:59 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-17 07:55:58
[2019-07-17 11:08:40] |
Ah, yes. The new period setting was what I was missing. Thank you for your time.
