Date/Time: Sun, 19 May 2024 18:16:53 +0000
Line/Targets to change quickly via spreadsheet
View Count: 1163
[2019-07-16 15:26:59] |
osaga - Posts: 53 |
Hello Every day I have 3 new target above and below the open (6 total). These are custom targets that I need to change every day. Is there a way I can use a spreadsheet to change the price of these 6 targets and when I make the change it will move these lines on the chart? I've been trying to find the answer online for a while now with no success. Thank You |
[2019-07-16 16:59:51] |
Yes this can be done by using the Spreadsheet study: Using the Spreadsheet Study You can use the formula columns to draw lines on the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
