Date/Time: Sun, 19 May 2024 14:15:04 +0000
Drawings shifted out of view
View Count: 546
[2019-07-16 15:21:43] |
User462086 - Posts: 193 |
Hi, I have a chart with 2 regions: price & cumulative delta volume (not reset at session start). Both have drawings/annotations for each day in June. I wanted to review these mark-ups today but found the cumulative delta region to contain only the cumulative delta series. Upon further investigation I realized all the drawings have been offset vertically and are now out of view. I assume this occurred because I needed to add more days to the chart in order to view the full month of June. 1) How do I realign the drawings/annotations with the cumulative delta series? The Tools Management window doesn't appear to be of much help for this. 2) How do I make sure this doesn't happen in the future? Is there a way to set a chart's start and end date? Many thanks!! |
[2019-07-16 23:48:25] |
1. There is no automated method to realign the drawings. You would have to adjust them manually. 2. You can control the chart Start and End dates, by selecting the option under Chart >> Chart Settings >> Use Date Range. Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo Also refer to the following documentation regarding why the bars shifted relative to the drawings on the Cumulative Delta Bars - Volume study and other ways to avoid it: Cumulative Delta Bars - Volume: Using Drawing Tools on Cumulative Delta Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
