Date/Time: Sun, 19 May 2024 13:24:56 +0000
real time data feed with interactive brokers
View Count: 510
[2019-07-16 13:34:51] |
RoyM - Posts: 11 |
Dear, I wish to use real time data feed with SC Data- All services, and i am using interactive brokers. How can i connect to SC data realtime data feed? As far as i know, i have already paid for corresponding fees and can you check if I still need to subscribe any? |
[2019-07-16 19:16:48] |
You just need to follow the instructions here: Sierra Chart Exchange Data Feed: Integration with Trading Services (Integration with Trading Services) The services you have activated are correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-16 19:17:09
