Date/Time: Thu, 02 May 2024 02:06:32 +0000
Feature Request: Send File to User: Symbol Lists
View Count: 633
[2019-07-16 10:36:00] |
ticinotrader - Posts: 378 |
Dear Support, Can you please add the feature to the 'Send File to User' function to be able to send Symbol List files as well? Thank you. |
[2019-07-17 04:40:26] |
Yes we will support this.
[2019-07-19 17:09:47] |
User90125 - Posts: 715 |
Would you consider having Symbol Lists copied into the appropriate directory when a new instance is launched?
[2019-07-19 21:36:50] |
Do you mean the folder it originated from?
[2019-07-19 21:47:59] |
Yes, since the QuoteBoard, IFUL (intraday file update lists) and saved Watch Lists are dependent upon it.
[2019-07-20 18:59:03] |
Example from working sub-instance: Cannot import symbols. File does not exist: G:\SierraChart\SierraChartTransActMA\SierraChartInstance_2\Data\QB_20190720.SymbolList | 2019-07-20 14:19:43.717 *
