Date/Time: Thu, 02 May 2024 11:00:25 +0000
[Programming Help] - Need help with ACSIL
View Count: 571
[2019-07-16 02:15:08] |
User929084 - Posts: 60 |
Hi. I'm trying to build a study based off Bid Ask Difference and Volume, but I have zero experience with ACSIL ( did some copy and paste in NT7 ). Right now I have Bid Ask Difference study ( ID1 ) with moving avg ( ID2 ) and volume ( ID3 ) with moving avg ( ID4 ) on the chart. A signal is generated when bar closes up/down, bid/ask closes above the moving avg and volume closes above the moving avg. Right now I use Color Bar Based on Alert Condition to accomplish that. =AND(C>O,ID1.SG1>ID2.SG1,ID3.SG1>ID4.SG1) and =AND(C<O,ID1.SG1>ID2.SG1,ID3.SG1>ID4.SG1) I want to either color the bar or put an arrow under/ above the signal bar. Would that be easy enough or is it work intensive and better to just stick with what I use now? Any help is appreciated. Thank you. |
Attachment Deleted. Bid_Ask_&_Vol.1.png / V - Attached On 2019-07-16 02:13:58 UTC - Size: 18.66 KB - 235 views Bid_Ask_&_Vol.png / V - Attached On 2019-07-16 02:14:13 UTC - Size: 22.31 KB - 239 views |
