Date/Time: Mon, 06 May 2024 16:52:38 +0000
Filter Numbers in Number Bars
View Count: 2903
[2013-04-10 20:07:00] |
User22751 - Posts: 12 |
Hi, Can i request a feature to filter numbers showed in Number Bars, i am using Bid vol x Ask vol in number bars and would really like to only see number above certain given number. I know i can filter the volume via chart settings (Advanced settings 2) but that is actually filtering the overall volume but not the actual bid vol or ask vol in number bars. I hope you consider it as an important feature of using number bars and if alert can be added if the given threshold in number has been triggered. Thanks, |
[2013-04-10 20:25:05] |
So you are saying you want to hide bid volume and ask volume numbers below a certain level? We will see about the alerts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-10 20:26:38] |
Yes, that's correct. "hide bid volume and ask volume numbers below a certain level" Thanks, |
[2013-04-25 20:34:23] |
Hello, is there any update on this request.. Thanks |
[2013-04-26 03:55:42] |
We will try to have a look at this tomorrow.
[2013-04-26 15:13:03] |
Al SC Developer - Posts: 434 |
In 969, when available, there will be a new option: "Bid/Ask Volume Text Thresh". When you set this to a non-zero value, only the BidxAsk volumes above the specified threshold will be displayed.
[2013-05-07 20:44:13] |
Thank you. |
