Date/Time: Mon, 29 Apr 2024 19:19:28 +0000
ORDER FILLS
View Count: 628
[2019-07-15 17:00:34] |
BLAKE R - Posts: 23 |
HELLO, WHEN I PLACE A STOP LIMIT ORDER ON THE CHART, MY FILL PRICE IS AS MUCH 1.5 POINTS [ 6 TICKS ] OFF OF MY DESIRED PRICE [ NQ ]. WHY IS THIS HAPPENING? |
[2019-07-15 18:27:39] |
Is Trade >>Trade Simulation Mode On enabled?
[2019-07-15 22:28:32] |
NO, "TRADE SIMULATION MODE ON" DOES NOT HAVE A CHECK MARK NEXT TO IT.
[2019-07-16 00:09:52] |
Therefore, check this setting on the Set tab of the Trade Window to make sure the limit offset is where you want: Basic Trading and the Trade Window: Set >> Stop-Limit Order Limit Offset Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
