Date/Time: Sun, 19 May 2024 13:39:15 +0000
Candlesticks pattern finder
View Count: 763
[2019-07-15 00:25:40] |
arruga - Posts: 249 |
Hi I added the Candlesticks pattern finder study.. all good, but then when ticking the hide box, it's not actually hiding, it remains visible http://www.sierrachart.com/image.php?Image=1563148841878.png ?? |
[2019-07-16 20:07:14] |
hello!
[2019-07-17 04:20:46] |
Because of the nature of how the Candlestick Patterns Finder places the text on the chart, it does not remove the text when you hide the study (the text is actually drawn as a Drawing Tool, and not as a Subgraph of the study). Therefore, you need to set the Input for Display Text in the study to No to hide the text in this case. Refer to the information for this Input within this section of documentation: CandleStick Patterns Finder: Inputs In the next release the study will support the Hide Study setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-17 04:21:28
