Date/Time: Fri, 03 May 2024 01:20:24 +0000
[User Discussion] - Alert with arrow up/arrow down
View Count: 2676
[2013-12-03 11:02:50] |
User59474 - Posts: 13 |
Hi, Please, i changed the settings of a crossover indicator on sierra chart, and it plots me arrow up and arrow down. These are good indications, and i want now to have an audio alert when the arrows appears, and/or a message. Please, can you help me with a complete how to, or an example template to download and adapt to my case myself? Thanks a lot |
[2013-12-03 19:48:18] |
Please refer to this page: https://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-03 21:32:36] |
Sawtooth - Posts: 3992 |
These are good indications, and i want now to have an audio alert when the arrows appears, and/or a message What is the name of the crossover indicator? |
[2013-12-04 10:54:49] |
Thanks Sierra for your help, i'll apply the examples. Hi tomgilb; You don't say neither hi, hello, nor please, thanks, cordially? And you really want a constructive answer? Only because you read "these are good indications"? |
[2013-12-04 13:35:41] |
Hi User59474, I have no interest in using your crossover indicator. Since not all indicators output the same value when a mark is applied, I was merely trying to determine what your indicator used before I offered an alert formula. Best regards, Tom |
