Date/Time: Sun, 28 Apr 2024 20:28:40 +0000
[Programming Help] - ACSIL - Only three Subrahps are being displayed on Chart
View Count: 645
[2019-07-12 12:46:51] |
User722856 - Posts: 78 |
Dear Sirs, I have programmed a simple study where i want to show four Lines (= Subgraphs) on my Chart. Unfortunately always only three are displayed by Sierra. --> sc.Subgraph[4] is not being plotted, why not? Did i something wrong or is this a bug? As far as i know (from the official documentation) 60 subgraphs are available. Please find the code and screenshot bellow. Thank you very much in advance. /*============================================================================
This function demonstrates manual Subraph looping using a for loop. ----------------------------------------------------------------------------*/ SCSFExport scsf_ExampleSubgraph(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "Subgraph Example"; sc.StudyDescription = "This is an example of using manual looping in Subgraph."; sc.AutoLoop = 0; // 0 is the default: there is no auto-looping sc.GraphRegion = 0; // Use the main price graph region (0 means Chart Region 1, 1 means Chart Region 2, maximum value can be 7=Region 8) sc.Subgraph[1].Name = "High-Min"; sc.Subgraph[2].Name = "High-Max"; sc.Subgraph[3].Name = "Low-Min"; sc.Subgraph[4].Name = "Low-Max"; return; } // Do data processing for (int Index = sc.UpdateStartIndex; Index < sc.ArraySize; Index++) { //================================================================================ // Calculate the Upper Range (from Daily Low) //================================================================================ // Calculate the Upper Range (from Daily Low) - High-Min: sc.Subgraph[1][Index] = sc.BaseData[SC_LOW][Index] + 20; // Calculate the Upper Range (from Daily Low) - High-Max: sc.Subgraph[2][Index] = sc.BaseData[SC_LOW][Index] + 40; //================================================================================ // Calculate the Lower Range (from Daily High) //================================================================================ // Calculate the Lower Range (from Daily High) - Low-Min: sc.Subgraph[3][Index] = sc.BaseData[SC_HIGH][Index] - 20; // Calculate the Lower Range (from Daily High) - Low-Max: sc.Subgraph[4][Index] = sc.BaseData[SC_HIGH][Index] - 40; } } Date Time Of Last Edit: 2019-07-12 13:00:19
sierra.png / V - Attached On 2019-07-12 12:44:49 UTC - Size: 25.19 KB - 231 views |
[2019-07-12 13:05:09] |
Ackin - Posts: 1865 |
[4] was ignored (as DRAWSTYLE) SCSFExport scsf_ExampleSubgraph(SCStudyInterfaceRef sc)
{ if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "Subgraph Example"; sc.StudyDescription = "This is an example of using manual looping in Subgraph."; sc.AutoLoop = 0; // 0 is the default: there is no auto-looping sc.GraphRegion = 0; // Use the main price graph region (0 means Chart Region 1, 1 means Chart Region 2, maximum value can be 7=Region 8) sc.Subgraph[1].Name = "High-Min"; sc.Subgraph[1].DrawStyle = DRAWSTYLE_LINE; sc.Subgraph[2].Name = "High-Max"; sc.Subgraph[2].DrawStyle = DRAWSTYLE_LINE; sc.Subgraph[3].Name = "Low-Min"; sc.Subgraph[3].DrawStyle = DRAWSTYLE_LINE; sc.Subgraph[4].Name = "Low-Max"; sc.Subgraph[4].DrawStyle = DRAWSTYLE_LINE; return; } // Do data processing for (int Index = sc.UpdateStartIndex; Index < sc.ArraySize; Index++) { //================================================================================ // Calculate the Upper Range (from Daily Low) //================================================================================ // Calculate the Upper Range (from Daily Low) - High-Min: sc.Subgraph[1][Index] = sc.BaseData[SC_LOW][Index] + 20; // Calculate the Upper Range (from Daily Low) - High-Max: sc.Subgraph[2][Index] = sc.BaseData[SC_LOW][Index] + 40; //================================================================================ // Calculate the Lower Range (from Daily High) //================================================================================ // Calculate the Lower Range (from Daily High) - Low-Min: sc.Subgraph[3][Index] = sc.BaseData[SC_HIGH][Index] - 20; // Calculate the Lower Range (from Daily High) - Low-Max: sc.Subgraph[4][Index] = sc.BaseData[SC_HIGH][Index] - 40; } } Date Time Of Last Edit: 2019-07-12 13:08:12
[2019-07-12 13:12:46] |
@Ackin [4] was ignored (as DRAWSTYLE)
Thanks for the Response. How do I achieve that it wont be ignored? |
[2019-07-12 13:54:17] |
ACSIL) add this line: sc.Subgraph[4].DrawStyle = DRAWSTYLE_LINE; or manually) in Study settings in TAB "Subgraphs" change DRAWSTYLE from "IGNORE" to "LINE" Date Time Of Last Edit: 2019-07-12 13:55:43
subgraphs.png / V - Attached On 2019-07-12 13:54:14 UTC - Size: 77.6 KB - 238 views |
[2019-07-12 19:57:33] |
Thanks it works now!!!
