Date/Time: Mon, 29 Apr 2024 05:48:03 +0000
Customize Max Levels Depth in a DOM
View Count: 2997
[2019-07-12 11:35:16] |
User710679 - Posts: 43 |
Hi, is there any way to customuze the max depth levels but only applied to a DOM. I know we can set it up in Data/Trade service settings, but that applies to all the DOMS and Charts. I would like to apply it only to a DOM if possible. Thanks, David |
[2019-07-12 18:18:54] |
Yes with this particular setting in the Chart >> Chart Settings for the Trading DOM: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-12 18:53:49
[2019-07-12 19:15:12] |
perfect! this is exactly what i needed! thanks |
