Date/Time: Fri, 03 May 2024 09:55:10 +0000
4 charts replay
View Count: 1475
[2019-07-11 15:26:31] |
User255315 - Posts: 127 |
Hi SC, I wanted to ask you will SC manage to replay 4 charts (i am using data intensive product E-min S&P), and use two TPO charts and two daily charts for the entire simulation. I wanted to know any limitations regarding this. Thanks in advance! |
[2019-07-11 22:06:53] |
There are two options available to replay multiple charts. You can either replay all the charts in the chartbook, or you can replay the charts that have the same link number. Refer to the following for the Charts to Replay options on the Chart Replay page: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ChartsToReplay Regarding, replaying the Daily charts, refer to: Replaying Charts: Replaying Historical Daily and Higher Timeframe Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-11 22:09:57
[2019-07-12 03:00:21] |
That is fine but would a system be able to process that much data in real time if i deploy a study that uses 4 charts? on e-mini which has particularly high volumes
[2019-07-12 03:24:20] |
Yes this is not a problem.
