Date/Time: Mon, 29 Apr 2024 10:00:06 +0000
'Do Not Draw Columns With No Data' option
View Count: 889
[2019-07-11 06:09:05] |
User884103 - Posts: 19 |
Hi I am looking to exclude columns on a TPO chart during the exchange lunchtime period as this column intereferes with POC and value calculations. I have selected the 'Do Not Draw Columns With No Data' option in advanced settings (also have unselected 'allow zero values') but the column still appears. I have also tried to exclude the lunchtime period by using the morning session and evening session times (for before and after the break). However, the two sessions do not automatically merge to form a daily profile and this also excludes the possibility of using evening session profiles, which is not ideal. Is there a way that I can exclude this time period and keep the daily TPOs intact? Thanks |
[2019-07-11 16:12:56] |
We do not recall anyone wanting to do this before. For what symbol? There really is not a practical way to accomplish what you need. I have also tried to exclude the lunchtime period by using the morning session and evening session times (for before and after the break). However, the two sessions do not automatically merge to form a daily profile and this also excludes the possibility of using evening session profiles, which is not ideal. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-11 16:13:04
[2019-07-12 03:29:49] |
The symbol is HSI (Hang Seng Index - HKFE)
