Date/Time: Sun, 28 Apr 2024 08:15:02 +0000
Attached orders and Spreadsheet System
View Count: 658
[2019-07-10 09:46:40] |
User564539 - Posts: 27 |
I am currently using a spreadsheet to generate buy and sell limit orders where the limit prices are based on some formulas. But i want also to use the Attached Orders for my stop loss. When i place a buy limit order, SC is sending both the stop loss and the buy limit order. When the order is filled, the sell limit order is triggered, but then it overrides the stop loss already sent. How can i keep both stop loss and sell limit after buy is filled. Attached orders works fine to keep all 3 orders stop loss, buy limit and sell limit however i cannot base the buy and sell prices on formulas in the spreadsheet. |
[2019-07-11 21:18:42] |
This is confusing. We are not understanding this. Are you experiencing a problem or an order is unexpectedly filling? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-12 07:33:27] |
Basically i am saying if i use Attached orders feature with the stop loss only, and the spreadsheet generates the buy limit and sell limit order, what is happening is that the sell limit generated by the spreadsheet is overriding the stop loss sent by the attached orders e.g. 1. send a buy limit @$12,000 from spreadsheet 2. send a stop loss from Attached orders of $11,900 3. once buy limit is filled then spreadsheet generates a sell limit order of $12,500. 4. stop loss of $11,900 is now updated to $12,500 I expect that i keep the SL of $11,900 and keep the sell limit of $12,500 |
[2019-07-15 04:42:52] |
3. What cell is generating this order? 4. Why would this be the case? These are separate orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
