Date/Time: Sun, 19 May 2024 08:47:55 +0000
Using Attached Orders, Trade Management Study and Spreadsheet System for Trading
View Count: 518
[2019-07-09 11:37:39] |
User94606 - Posts: 327 |
If you use attached orders for stop losses (10 tick), add the trade management study for trailing stops and use the Sell Exit (Column N3 on the spreadsheet) all of them on the same chart, if all of these 3 rules are enabled, which one takes precedence in terms of rules being triggered first, second or third?
[2019-07-10 05:18:08] |
They all are operational at the same time. This is the only way we can answer the question.
