Date/Time: Tue, 28 May 2024 04:31:12 +0000
Referencing Chart Drawings in a Spreadsheet Study
View Count: 1395
[2019-07-08 12:04:23] |
User247273 - Posts: 37 |
What I'm trying to achieve is to display the value of a chart drawing in a cell on a spreadsheet study. I thought using the formula =UDID[#].A# might work, but it didn't. Is there a way for me to acocmplish this? If not, is it something you might add in the future? If that's unliikely, could you tell me if its the kind of thing a developer could accomplish with some custom programming? By way of context, my end goal is this: I have values from various study subgraphs on worksheets for the charts they're plotted on. I also have a lot of drawings whose values I'd like to see in relation to those various subgraphs. Ideally, I'd like to create a worksheet where I can coalate (and possibly sort) those references to give me an overview of how they all relate to one another. Seemingly that would mean a column of simple formulas that might look something like the one below, but I get the feeling it's not that simple. =Sheet12!AA3 =Sheet20!BC3 =UDID[321].A1 =UDID[321].A2 =Sheet17!AM3 etc. |
[2019-07-08 18:38:21] |
This is not supported. If that's unliikely, could you tell me if its the kind of thing a developer could accomplish with some custom programming? Yes because ACSIL can access Chart Drawings and can also interact with cells on a Spreadsheet.
