Date/Time: Sun, 05 May 2024 22:51:32 +0000
Tick & Advance/Decline
View Count: 504
[2019-07-03 14:23:30] |
User952251 - Posts: 1 |
Tick ("TICK-NYSE") and Advance/Decline ("NISS-NYSE) do not seem to work for me unless I use version 1918 or older. When trying to use 1920 or newer I receive a download failed message on the chart.
Download Failed.PNG / V - Attached On 2019-07-03 14:20:52 UTC - Size: 31.24 KB - 190 views Attachment Deleted. |
[2019-07-03 15:06:33] |
Follow the instructions here to update Sierra Chart to the current version: Software Download: Fast Update After that, follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
