Date/Time: Sat, 18 May 2024 04:54:39 +0000
How to set up tick chart
View Count: 8968
[2019-07-02 22:50:33] |
User170821 - Posts: 5 |
Hi, I use tick chart to trade the Futures, and there is no tick chart button on the main window. May i have the instruction for setting up the tick chart. Thank you. |
[2019-07-02 22:57:11] |
Sawtooth - Posts: 4000 |
Use 'Number of Trades per Bar'. Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu) Date Time Of Last Edit: 2019-07-02 22:58:19
[2019-07-05 16:45:03] |
Yes, you need to use the Number of Trades Bar Period Type: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu) You can also set up custom Control Bar Buttons for that setting: Changing Chart Bars Period: Changing the Period of the Chart Bars Through Control Bar Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
