Date/Time: Sat, 04 May 2024 03:21:13 +0000
Chart fills are out of sync
View Count: 611
[2019-07-01 19:02:14] |
User431785 - Posts: 20 |
My chart fills are of out sync. How do I reset this?
[2019-07-01 21:07:19] |
You just need to adjust the Order Fills Start Date-Time in the Chart Settings as explained here: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
