Date/Time: Sat, 04 May 2024 02:36:51 +0000
Chart trading- color of order lines
View Count: 726
[2019-07-01 12:05:27] |
User525965 - Posts: 153 |
I went to global settings and changed the color of these order lines but nothing has changed on my chart. Can you please assist? I would like my entry line to be cyan, the stop order line to be red and the target order line to be green. Also, the market data on the right price axis, how do i change the color/size of that so i can read it better? Also, is there a way to only see the highest bid and lowest ask, instead of the entire order book? |
sierra chart order colors.PNG / V - Attached On 2019-07-01 12:04:52 UTC - Size: 103.35 KB - 272 views |
[2019-07-01 17:39:18] |
Therefore, you need to change the colors through the chart specific Graphics Settings window (Chart >> Graphics Settings-Chart). This is explained in detail here: Graphics Settings Also, the market data on the right price axis, how do i change the color/size of that so i can read it better? Refer to this page:Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM Also, is there a way to only see the highest bid and lowest ask, instead of the entire order book?
The DOM Graph specifically has an option to support this:Trade Menu: Draw DOM Graph on Chart (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-01 17:40:04
