Date/Time: Sun, 28 Apr 2024 20:10:38 +0000
One chart, multiple chart links
View Count: 983
[2019-06-30 21:26:49] |
User606491 - Posts: 164 |
A chartbook contains 4 charts. I would like Charts A & B to share a "studies" link. I would like A & C to share a "symbol" link. I would like B & D to share a "symbol" link. Said differently, Chart A shares Link 1 with B and Link 2 with C. Chart B shares Link 1 with A and Link 3 with D. Is this possible? Can you point me to the documentation? thank you |
[2019-07-01 18:10:53] |
You can do some of what you are asking for, but not all of it. To begin with, each chart can only have 1 link associated with it. But, each chart can then have different settings for what link options are associated with it. Therefore, it is possible to have charts A and B be Link 1 with both set to Studies. And then have charts A and C be Link 1 with both set to Symbol. But, you cannot then add B and D to share a Symbol, as doing this will add the selection of Symbol to Chart B, which will now associate its symbol with that of A and C. Refer to the following documentation on this: Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
