Date/Time: Wed, 15 May 2024 05:10:36 +0000
[User Discussion] - IQFeed / Message Log
View Count: 593
[2019-06-30 18:32:57] |
D WING - Posts: 2 |
Hello, I am using IQFeed, and this message log opens every time I start SC. Do you see any problems here? According to your website, this message window would only open automatically if there are issues. Thank you, https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=29528 |
[2019-07-01 15:15:02] |
This is the only line we see which is causing the Message Log to open: Cannot import symbols. File does not exist: C:\SierraChart\Data\MAIN DT SYMBOLS.SymbolList.SymbolList | 2019-06-30 11:27:52.111 Otherwise, we see no obvious issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-01 15:15:34
