Date/Time: Sat, 18 May 2024 03:52:11 +0000
2 FCMs
View Count: 651
[2019-06-28 19:32:17] |
User545800 - Posts: 13 |
Team - I have 2 FCM accounts. one through TT another through CQG. Is this feasible to trade by changing the CQG FIX for CQG fcm and TT for TT FCM. Please confirm.
[2019-06-28 19:46:09] |
To further clarify, TT is thro sierra chart order routing.
[2019-06-28 20:20:10] |
Ok in this particular case you need to have two separate installations of Sierra Chart. How to do this is explained here: Using Multiple Data and Trading Services at the Same Time If both of the accounts were through TT they could both be used within a single installation of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-28 20:20:43
[2019-06-28 20:29:35] |
Got it. Will follow the instructions of the thread. Thanks.
[2019-06-28 20:41:43] |
Please configure CQG for Advantage as well. That way I could use same installation for both. Thanks for the help.
[2019-06-29 13:06:56] |
There is nothing we need to do in regards to this. You just need to follow through the CQG set up instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-29 13:07:52
