Date/Time: Sat, 18 May 2024 06:01:24 +0000
Questions about chart drawings
View Count: 539
[2019-06-28 16:01:18] |
Tony - Posts: 461 |
Hi, I have 2 questions about drawing tool. 1, is there a study that I can display value of a drawing, for example: the price level of a horizontal line, similar to "Text Display For Study" study? 2, I know I can copy drawings from another chart in chart settings, is it possible I can choose which drawing to copy instead coping all of them? Thanks very much! |
[2019-06-28 16:10:48] |
1. The easiest way to do this would be to use the Spreadsheet Formula study. You can then reference the anchor points as discussed here: Study/Chart Alerts And Scanning: Referencing Chart Drawings Then you can use that Spreadsheet Formula subgraph in other studies as needed. 2. This is not supported. You can only copy all the drawings, and any actions performed on the drawing in either chart is going to reflect in the other one (such as hiding the drawing). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
