Date/Time: Fri, 03 May 2024 13:04:01 +0000
Ensuring Sierra Charts is not lost when changing brokers
View Count: 1163
[2013-12-02 02:11:42] |
Hello, There is no connection between your charts, Chartbooks, and other settings and your Sierra Chart account. You just need to make sure you copy your Data Files from the copy of Sierra Chart you are currently using to the copy you will be using, assuming they are different. More information can be found in help topic 15 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
