Date/Time: Sat, 27 Apr 2024 13:00:35 +0000
Clrification on "Peak and Valley lines with labels..." please.
View Count: 1290
[2013-12-01 18:22:52] |
Rino - Posts: 124 |
In release •1055 Release Date: 2013-11-30 you state "◦The TPO Profile Chart and Volume by Price studies now both fully support Peak and Valley lines with labels. Peak and Valley lines have the following extend options: None, Extend to End of Period, Extend to End of Window, and Extend To Intersection." This just means you can use Peak and Valley with TPO charts. (If you have VBP added) correct? You still do not support having level labels on (any) VBP charts such as http://www.sierrachart.com/image.php?l=1385922056764.png Correct? Thanks |
[2013-12-03 10:14:55] |
We do see a problem with the labels when using the Volume by Price study. We are looking into this.
