Date/Time: Mon, 06 May 2024 11:52:30 +0000
Running multiple live chartbooks
View Count: 993
[2019-06-26 06:06:49] |
User255315 - Posts: 127 |
Hi SC, I am currently running an automated trading custom study on multiple products, open in different chartbooks, on one instance of sierra, using the SC Futures Order Routing service. I wanted to know, since Sierra does all calculations on a single thread, do different chartbooks use the same thread? If so, would i require a different setup than i described above to effectively run the study on say 5-6 products simultaneously? Thanks in advance! |
[2019-06-28 02:44:27] |
Refer to these two particular sections: Using DTC Server for Data and Trading in Another Sierra Chart Instance (using multiple instances to distribute CPU load to multiple cores) Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
