Date/Time: Thu, 03 Jul 2025 04:27:43 +0000
Issue making the study-name and input values NOT showing up
View Count: 909
[2019-06-25 14:52:18]
BrMa - Posts: 80
Dear ladies and gentlemen,
when compiling my latest source with the actual version (1939) I'm receiving a compiler-error at the following line, saying the parameter does not exist:
sc.GlobalDisplayStudyNameSubgraphNamesAndValues = 0;
Question: did you remove this function? It disappeared from the documentation on the website but I didn't find anything in the changelog?
However, I tried to replace this function by putting the following lines in the code:
if (sc.SetDefaults) {
sc.DisplayStudyName = 0;    // Do not show study name
sc.DisplayStudyInputValues = 0;  // Do not show input values
Unfortunately the study-name and the input values still show up at the top of the window.
Is this a bug or am I missing something to prevent the study-name and input values showing up at the top of the window?
Thanks a lot in advance for your support!
Regards, Markus
[2019-06-25 16:29:16]
Marmany - Posts: 312
Same issue here.
Please bring back sc.GlobalDisplayStudyNameSubgraphNamesAndValues = 0
It removed the need to untick "Display Study Subgraphs Name and Value" and "Always Show Name and Values When enabled" as well as Study Name and Input Values.
[2019-06-25 18:15:48]
The new variable is:
sc.GlobalDisplayStudySubgraphsNameAndValue
This cannot be true. Remove the study from the chart and add it again. The study Name and Input values definitely will not display unless you re-enabled them. Keep in mind these are different from the Subgraph Name and Values.
Date Time Of Last Edit: 2019-06-25 18:16:10
